GT 32 with t04 housing
Re: thanks
Originally posted by sdteb
where in fla are you...my dad lives in mt dora....
I live over in the Space Coast, Brevard County, cocoa beach area.;)
Originally posted by postal
Louie:
Are you running a GT32 from precision or are you running one the way garrett makes them? Also maybe I should ask to make sure, but if you buy a precision one, aren't they modified to bolt right on?
I'm really curious to see if any one has tried an off the shelf garrett GT turbo. You can buy one pretty cheap. Like a GT30R ball bearing turbo which is actually rated about 80hp higher than the GT32 for I think $1200. GT35 for $900, GT35R ball bearing for $1500, GT37 for $725, GT40 for $816.
That GT30R ball bearing seams like it would be a crazy little turbo to try out.
Jason
Mine is a PTE version. It was a bolt on, but when you look at one , the brackets and housings look different.
downpipe for gt32-55
will an atr downpipe help alot on this car?
Re: downpipe for gt32-55
Mine was on the car when I got it, so I'm not sure how much it helped, but I assume that it helps quite a bit. Anything to make more air flow will make your car faster, and that is what the ATR setup does.:)
