GT6131E Limited Engineering Turbo
tbirdv6
New/Barely Used, Have 4 Saturday Nights going to Car Show (Could easily say less than 500 miles)
Quick Spooling, works great w/stock stall & up to 3400
Purchased from Full Throttle & Speed-still has warranty
John Craig (Limited Engineering)
.63 exhaust housing
You supply your own waste gate actuator
Reason for selling = got itch, have a bigger stall, going to ported heads, want 45,67, or 70 series turbo
$650 shipped
Won't be disappointed!!
FRED
turbobuick2@yahoo.com
Just a Six?? said:
How would this compare to a 49? 60? Thanks!
Imagine having the quick spool up using a similar turbine wheel as TE44, but a much more efficient GT compressor wheel for more power? That's the turbo he is selling. If you have an opportunity, look up the compresor map for a GT-35R because it uses the same compressor wheel.
I have about 850 miles on my setup using a PT/GT6152E and the car pulls everywhere in any gear. I'm running 17 degrees of timing, 3K stall & 20 psi on straight 93 and can't use 1st or 2nd gear and don't get any knock in 3rd. If I didn't have mine, I would buy it.
