GTA wheels
pm87tb
Hi guys just want to know how bad does a set of gta mags look on a car when you have to front and to rear wheels is it that much of a differince ? or will it look ok ? thanks...
I have the GTA fronts on the rear and the rears on the front. Of course, I have B-Body spindles on front which moves the wheel outboard somewhat, making room for the rears to fit on the front. Works great for me. If you are using the stock spindle, you will have to use a spacer and I would not recommend that as the wheel studs will have to take all the load.
Conrad
I have Baer brakes on my 2+2 and use GTA Rears in front with no spacers.
They actually fit the fenders better than GTA Fronts because of the extra wheel offset caused by the thicker brakes.
GTA Rears in back will rub the frame rail without a spacer.
