It has been proven time and time again that long runners create low end torque. Why do you think all the new cars come with long runners on their manifolds? even the low rise intakes on new cars have long tubes on them. Look at the LS manifolds they have long runners. The real difference is the size of the runners and the ports. So while you may gain upper RPM hp and torque from gutting and porting your intake you will loose some bottom end torque. This can be made up some by changing cams or even the converter to take advantage of the new torque curve. These intakes may be restrictive but they do make gobs of torque on the bottom end but they just can't flow enough volume to breath as good on the top end. Don't flame me I am not saying that they can't make power, they just can't flow enough to keep up with a really good set of heads.
