That's basically what I've been running for a few years, using a 3" LT1 MAF ...............but I gained about 1.5-2 psi boost and just noticeable quicker spoolup on a Limit ptrim GT67 plain bearing turbo just from moving the maf and changing the inlet hose from 3" to 4".
Looks like the boost pickup.... tells us that without a doubt... on your car.... that moving the 3" LT1 MAF meter... from the suction side.... re-locating it to the up pipe.... was less of a restriction.... even though the same air would go through it in both locations.... The fact that you picked up 1.5-2 psi boost.... meant your turbo was a little more efficient.... and if you cut the boost down 1.5-2 psi .... to be at the same boost as you were at prior to the swap.... you would likely make more power... at the same exact boost.... cause the turbo was actually not having to work as hard to achieve the same boost....
Am I making any sense....
At least this is how I see it....
