SignUp Now!looks good. i cant wait to install mine
I currently have a similar setup on my GN (H&R sway bar + upper adjustable control arms + fixed lenght lower ca's...). H&R's parts fit and finish is excellent...BUT...since I've installed the sway bay, my car NEVER was able to launch as hard as it did before...:frown: My car used to leave the line with both wheels off the ground but now, it does but only an inch or so. I'm dissappointed of the end result. Yes, it did leave the line crooked with one side of the car higher than the other, but it was FUN and gave a good show ...but not anymore.
Claude.![]()
Claude.![]()
did your times improve![]()
same times but lauches straight,hummmmm
Do the bars help the car handle better through the turns?
I have a heavy ATR style bar. Every once in a while when turning slow I get a big thunk even though it's tight. Never did that with the stocker. Does this setup do that too? I see you welded the brackets to the axle housing too. Did you do the ones on the body too?
