Hello I have a speedpro bank2bank/w wb02 on a 93 LT1 Supercharged Vette running a moderate 5PSI of Boost. I am having a problem with getting the car to start reliably.
When starting cold you have to crank the starter for a good 10 seconds before it starts. I was told that I should add some fuel in the cranking table which I did. It did not seem to make much difference so I added some more... than obviously I had to much because after the car started it was definitely flooded tons of black smoke etc.
Are there other parameters and/or tables that I should be manipulating in addition to the Cranking fuel enrichment table. Also my IAC is still set extremely high around 200 in order to allow the car to Idle properly.
Other than that driveability is good... and WOT is excellent!
BTW, after the car gets warmed up it starts as expected. What am I missing?
Doug
Doug
