Harlan's twin turbo LS1 Firehawk runs 8.93 @157mph **Video**
Yes a local guy last night went 10.9x@144.6x mph, LOTS of wheel spin.
Full weight car.
It's his daily driver/only car.:eek:
Originally posted by gnx7
that is insane.... I assume an iron block was used.
-Mark
You ASSume wrong!:D It's a stock LS6 aluminum block bored .010 over with a stock crank (that makes it 347ci), crower Billet rods, JE pistons, ported LQ9 heads, LS6 intake, custom solid roller cam, custom 321 stainless headers/3.5" DPs, twin T-66 BB turbos, Liquid/air IC, and from what I heard the car weighs 3500lbs w/ driver.... That's about all I can remember off the top of my head... It originally had a 6-speed, but he obviously ditched it for a slushbox with a trans-brake.....
The intake is not a LS6. Its a carb. one converted to F.I.:D . I was there that night. Matt's car runs/looks great.
On another note....They were running a 10.5 tire heads up shoot out that night. A buddy of mine runs a turbo Mustang and ran a 7.86@180.98:eek: . Thats with a 347ci, 98mm single turbo, and a blow through carb. I heard it was the fastest carb./turbo pass ever. I don't if thats true or not. Anybody know?
Scott
Nice run! Anyone have any idea whats in there for a suspension setup? Looked like a nice, balanced launch. :)
Originally posted by 86brick
You ASSume wrong!:D It's a stock LS6 aluminum block bored .010 over with a stock crank (that makes it 348ci), crower Billet rods, JE pistons, ported LQ9 heads, LS6 intake, custom solid roller cam, custom 321 stainless headers/3.5" DPs, twin T-66 BB turbos, Liquid/air IC, and from what I heard the car weighs 3500lbs w/ driver.... That's about all I can remember off the top of my head... It originally had a 6-speed, but he obviously ditched it for a slushbox with a trans-brake.....
Scott, doesn't look like a carb converted to EFI to me, but if you say so...
http://hauln.net/LS1Tech/members/Harlan/
http://harlan-engineering.com/projectBFT/
Matt, I'm not sure what the suspension setup is, but the 60' on that 8.93 pass was a 1.41....
BTW Scott, this must be the Mustang you're talking about...
http://www.turbomustangs.com/feature_cars/bradblowthru.htm
Probably a nice BMR setup out back, with either HAL shocks, or Afco's.... 1.4X is easily done on a stock style setup.
Not that I'd know ;)
Yeah I'm sure he has a lot more left in it with some tuning and a harder launch.... I think they said that was his first time launching off the trans-brake....
I'm sure you'd know cause I happen to remember a certain Chevelle looking at your tail lights:D
Originally posted by NEARING
The same daily driver I mentioned earlier put a tire on the car later in the night and went 9.92 /144.xx
16.5 psi boost, single T-80.daily driver time slip!
http://www.turbomustangs.com/turbogms/featuredcars/mightymouse.htm
The TTI LS1 Race Kit he has on the car sells for almost $9K....
http://www.turbotechnologyinc.com/ls1_race_system.htm
:eek:
He has a LOT of $$$ in that car (pretty much like building a Stage2 car), but it's still very impressive for a daily driver!
Yes he has an ass load in that car but it's still very impressive!
Around 50k in it!:eek: Not including the car.
I'm pretty sure that he runs pump gas and a Snow alky kit on it.
Didn't know it was a liquid intercooler.
I wonder if the Snow alky kit he has is a progressive system like the one Razor sells?? It says that he runs a 50/50 mix of water and methanol, but it doesn't say if it's progressive.... His car is a 6-speed and I think it might be the fastest poweradder 6-speed LS1 Fbody...
Alan Futural (The one who sponser's Lee Camaro) went 9.89. :)
Edit: That's a nitrous 6 speed car :)
Okay that would make Alan the quickest (ET), but not the fastest (MPH).... Actually I think Alan ran 144mph so he's tied with this guy, but MightyMouse probably has the quickest and fastest FI (Forced Induction) 6speed LS1 F-body.... Harlan ran 10.00 @140+mph when he had the Incon TT kit and a 6speed, but now he has a PG....
