Sorry bout the resolution. This was done on a VHSC and converted to .jpg.
12 pulls were done, the first tests were done on Isopropyl 70/30 after the third run and had the Iso dialed in at 16 PSI, I dropped the ISO out and replaced with straight methanol. Next pull not changing anything.. the motor picked up 10 RWHP across the board. AFR dropped from 12.1 on iso to 11.9 on methanol. So getting rid of the water made more power...shhh..dont tell the other guys this
Turbo outlet temps were 250 at 16 PSI, you can see the thermocouple wire in the bottom pixs, intake air temps were 140's. So we were getting a reduction of approx 40% air temp.
Next pull we did without alcohol and matched the results of the thermocouple probe and IAT sensor inside the intake. That pull was cut short seeing the temps rise pretty steeply.
Time for more boost.. next pull was to up the boost, we ended up with a not too flat curve due to the way the dyno loads the motor/turbo. 23-25 PSI was were it hovered at. Turbo outlet temps were 300's, IAT was in the 170's. Again the same ratio of 40 %. Motor made 670 rwhp at this point(Super Flow Dyno). I asked Cal how much fuel was being replaced at this point??? His answer was 30%.
Next pull we decided to increase the alcohol and see if the temps could further be reduced.. well the temps came down to the 140's.. but the power dropped of to 610 rwhp. Even tho the AFR stayed at 12.0. So there is a point whereby too much will cuase the loss of RWHP.
Next pull..running out of time.. we dropped the C16 out of the tank.. and ran the car on straight methanol. It produced the same results as the previous test.
Next pull we switch the alky kit off, running on straight methanol, and the IAT temps started coming up as well as the injector DC goes to 100% on 160 lb injectors
.. shut it down.
That ended the tests due to time. It was past 9 o'clock at night at this point.
So summary.. what we wanted to achieve was the same results as his V3 front mount which weighs 60+ lbs. His car see's aprox 140's at high boost using the V3. We got 170's. We didnt hit the number. Altho his old smaller front mount would see 170's. So its a good guess that if a smaller high flow stock location can be used... and get a 30 degree temp drop out of it.. from 170's to 140's.. we'd replicate the results of the V3. And save on the weight.
Next thing.. tests were done on C16.. no ill effects of using C16 with methanol. The old saying...when you get to the track, switch the alky kit off and run C16.. doesnt hold water
To run straight methanol as a fuel get ready to double up on the injectors.. twice as much is needed to make the same power.
Guys running smaller IC and alky will note that swapping to larger IC a lot of times yields no improvement. This is something I know first hand. At least there is a test performed documenting why..
I have the FAST runs done on the car, the dyno pulls from Super Chips.. just need to figure a way of showing the results.. need some time. As soon as I have something up, i'll post the link.
Would like to thank Cal Hartline for the use of his car as a guinea pig
, and the team at Super Chips in Orlando for allowing us to beat on their dyno after hours..
So is Cal taking the kit off??? hehehe...
Lets see the V3 and alky test
coming soon...
