Hey all,
Have any of you had good luck fitting the larger group size Odyssey 34/78 battery in the stock location?
My car is stored most of the year so I want to try one of these Odysseys. It is also currently 1,000 miles away, so I can't measure right now
While obviously their stock 75 group size battery should fit fine (75-PC1230, 760 CCA, 110 RC) Id like to install the higher 850 CCA battery (34-78PC1500DT-A) if possible.
Odyssey's 34/78 is said to be 8/10ths of an inch bigger in length than my current 10-inch long yellow top (Odyssey is 10.85 inches in length), which if I remember correctly was a bit of a tight fit.
As my vehicle is currently 1,000 miles away, do any of you know the max amount of room, length-wise, that we can fit a battery?
