oldskoolrcr
- Oct 5, 2005
I know this is not a car but it is a Very fast Street/racebike, looking to sell it outright or would consider trades for fast street car, 8s bike on motor 159.9mph with 200lb rider, see the details below.
SUZUKI HAYABUSA, 2001 64" W/B
>>>Silver/Gray 02 body work. Flawless cond. 3,675 miles on the bike, CLEAN
>>>title in hand. Below is a list of the Mods to this awsome bike.
>>>Catlayst Low boy fiber glass tank, Painted to match factory color.
>>>6" over Catalyst fiber glass rear tail section, Painted to match factory
>>>color.
>>>Tinted double bubble windscreen.
>>>MPS air shifter w/on board compressor
>>>PC3 USB
>>>MPS kill switch
>>>LINK PRO. fully adjustable suspension link
>>>Nitros dry kit, with NX purge valve and nitros guage
>>>2lb nitros bottle, with bracket mounted in swingarm.
>>>3 hole lowering links
>>>Front strap
>>>Extended Tiger tail
>>>Tiger battery box
>>>McIntosh extended 600 swing arm, w/ McIntosh chain guard
>>>Brand new chain
>>>Brand new front/rear sprockets
>>>MSP Full exhust system
>>>Mickey shootout tire on rear, Shinko on front
>>>New shift forks
>>>New clutch
>>>HD clutch springs
>>>Welded clutch hub
>>>All new brakes
>>>Mirror block off plates
>>>JCS triple clamp
>>>JCS adjustable kickstand
>>>Cut down seat
>>>VIN# avalable upon request
>>>ENGINE MODS LISTED BELOW
>>>Motor is all new has 210 miles on it
>>>JE 1397 forged pistons
>>>Tool steel wrist pins
>>>Balanced/lightened crank w/gear removed by APE
>>>Case protector
>>>New suzuki rods w/APE rod bolts
>>>Brand new cam chain
>>>All new bearings
>>>High volume oil pump
>>>Billet high pressure oil valve
>>>Ported/shaved head with new valve seals
>>>Lazer cut factory suzuki head gasket
>>>APE springs and retainers
>>>APE head studs
>>>Brand new WEB cams 395/378
>>>New Yoshimura fully adj. cam sprockets
>>>Camshafts fully degreed
>>>This bike is in FLAWLESS COND in everyway, the motor has never been
>>>sprayed
>>>yet, not dynoed or tuned, Does not run hot very streetable,VERY fast has
>>>been to the track 1 weekend, first pass out 159.5mph 1/4 - 125.9 1/8 with
>>>1.42 60' w/195lb rider. Absolutley NO DISSAPOINTMENTS, There is nothing
>>>wrong with this bike, Well over 15K invested in this awsome street
>>>killer..
>>>FEW THINGS I LEFT OUT
>>>Dyna shift light
>>>Dyna shift minder
>>>Brand new 2lb nitros bottle
>>>Lees Perf. oil pan windage tray
>>>All nitros lines are steel braided
>>>BMC Race Filter
>>>Race
Please feel free to contact me with any questions 319-533-7052
Photos avil upon request, or may also be seen on "Psychobike.com" 4-sale section with photo.
$9750.00
>>>color.
>>>PC3 USB
>>>MPS kill switch
>>>Front strap
>>>Extended Tiger tail
>>>Tiger battery box
>>>Brand new chain
>>>New shift forks
>>>New clutch
>>>HD clutch springs
>>>Welded clutch hub
>>>All new brakes
>>>JCS triple clamp
>>>Cut down seat
>>>Case protector
>>>Brand new cam chain
>>>All new bearings
>>>APE head studs
>>>sprayed
>>>killer..
>>>Dyna shift light
>>>Dyna shift minder
>>>BMC Race Filter
>>>Race
$9750.00
