ShawnR
Fixer of crap..
- Jan 24, 2011
I recently bought a 109 block with caps already on it from another user on the forum.
https://turbobuick.com/threads/030-109-block-champion-heads.456273/
It had head studs in it already, so as part of the cleanup I removed them. 1 was already loose and only lightly screwed in. I look deeper and there is a helicoil in about 1/4 below the surface. I removed the helicoil fairly easily and find that it was not just stripped threads, the "socket" that goes into the water jacket is actually broken further in. This is on the top of the left side behind the first cylinder.
Options would be helicoil it and just not go very deep, Time-sert (never used it). Either of these ways, the head stud is WAY too long.
Or do I just hit John (the seller) back up and ask for my money back? I have a good 109 block, but would have to get caps fitted & that extra machine work if I go that route.
Thoughts?
Side view through the water hole.
Down the threads.
Thoughts?
Down the threads.
