Just replaced valve springs and on test run knock alarm went off around a 20lb spike then noticed a puff of oil smoke on decel & at idle on quick acceleration. No overheat, running fine w/ good idle , any thoughts??? Will pull plugs and go from there this morning. What is the best way to confirm gasket failure before un-necessary teardown?
