Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
I have a question for the guys that have sorted Gremlins. I have a nice new clean engine. I have a new TR6, wires, coil, etc. Everything on this engine has been replaced as new and from as far as I know seemed to be operating correctly. Today weather was nice, so I took it down the road to see if I could get the car for a drive. I have a stumble upon acceleration at approx 3000 rpm building in speed. Idle is fine. My 02 sensor is all over the place at idle after the drive mostly lean, that I do not know WTF. I tested for vacuum leaks last week with a redline smoke machine and only a small amount was leaking from the throttle body shaft. My plugs are new, gapped 34 and are NGK UR4
I have attached a power logger file and the stumble and chug/backfire through the exhaust starts at about 5mph on the PL file to about 20MPH. Everything seems fine according to the numbers??
Me and Eric from TT seem to think it is electrical. I dont have a means of testing to insure this is the issue. Any thoughts out there...? Short of me buying another ign module and swapping back to eliminate the the TR6 I need some other ideas if you would share.
All mods in the signature.
