Head studs - 86-87 FWD heads on stock block?
turbokinetic
Looking for part numbers for ARP studs to secure 86 - 87 model 3.8SFI front-wheel-drive heads onto a stock 3.8 block. This block is an 87 model and has the recessed threads in the deck.
I have the engine together as a "mock up" doing some turbo exhaust plumbing fabrication so I hate to disasemble it just to measure the stud dimensions.
I'm hoping someone else has done a conversion and took notes on ARP part numbers or stud dimensions! (please!)
If not I will pull a head and measure.
With these heads, the 4 studs along the outer edge are very short, and the center 2 under the valve cover are longer than those for the stock GN heads.
Thanks in advance!
Pictures here, scoll down to near bottom of page for current pictures.
Pictures on Car Domain
David
