Header bolts vs studs?
robertf
So the heads are coming back off this week. Factory headers with OEM bolts. Would it be easier to install studs? I know a couple of the bolts hold brackets so thats fine but thinking studs with nuts might make things a bit easier. Any recommendations?
Studs get it the way when removing and installing headers. The factory bolts work very well.
You can still use the factory bolts on aluminum heads just be careful
