headlights dont work
Raymond Jimenez
hi guys i got a problem my headlights stopped working one day and ive been searching for the problem ive read around here that the dimmer switch could be the problem so i swapped it out and nothing so i kept digging but before the headlights stopped working the radio stopped working and the chime when i put the keys in the ignition and then finally the headlights went out i checked the fuse that has tail lp on it and theres no power with the ignition on or off and havent really been able to find a good wiring diagram any help would be great my car is a 1985 buick t type
do you have dome light, under hood light? if all non ignition power sources are not working you could start at the fuse link at the starter or bulkhead connector on the engie side of fuse box
There is a fuse in box for the headlights. The silkscreen way have wore off above it. Keep digging until you find it!
