87gnblackdemon
Don't Be Redikulas!!
- May 24, 2001
I've decided to put my subs in the right size box and hand down my box to my sister. I've looked around and there aren't too many boxes big enough for what I need. Subzone has single 12" sub boxes that are 2.5 cu ft and they are perfect, but the advice I've been given is to try and build my own, so thats where I am.
I was told that 4x8 3/4" mdf would do me fine, and in order to get 2.5 cuft/chamber the box would have to be 36"wide, 17.5"high, bottom depth 18.5" and top depth 13.5 and all sides 3/4" thick. But when adding a port the measurements would be 17"widex17"widex20.5" deep, this would give me about 18" straight depth to extend a tube from front to back. Total dimensions for the entire box would be 17"hx33.25"wx20.5"d.
Right now I don't know if it would be better to split the box or have the subs share the air space, and if I'm going with one port or two. This is all for 2 12" vegas124dvc.
All these measurements were given to me, I did not do them.
Any different opinions on the measurements? Splitting the box? Or number of ports? Also what would you recommend I use to connect the mdf pieces so I don't hurt the cu ft space?
