SOLVED...code 31 Wastegate Solenoid
After driving my car today I got a code 31. The check engine light comes on when I get into the boost. Then it stays on. I am also simultaniously getting a code 13, o2 sensor. I have checked the wiring, and replaced both the o2 sensor and wastegate solenoid. And the problem is still there. I am using an adjustable boost control, and the solenoid is not used. But, It is still plugged in. Also, I am using a Caspers heated o2. And have been for 2 years.
I am not having any luck figuring this one out. Any help would be appreciated.
