Yo, Cope! Whatsa happening? An idle surge will be three things......a/f ratio, ve and/or timing. What's the timing like around where it idles? What af ratio? I find that I have to idle most stuff fairly rich....say 12.5:1. It's trial and error. Try changing the af lower at the idle spots and see what happens. If you've got a lot of timing at idle....say 30+ degrees, lowering the timing at that point will richen up the mixture so you may have to go back and forth a few times to nail it down.
