I'll share a little logic, I hope this doesn't offend anyone as it is
not directly addressed to the OP. Just a general observation and I chose to share it in this thread.
If your not in the habit of dropping new engines into Buicks every day................ then I'm not sure why anyone starts a fresh set-up without checking and double checking every single thing over and over!
Oil should be primed, all fluids checked twice. Hoses and fittings tight. Clamps tight. Electrical plugs and splices pulled-on shaken and checked. Vacuum lines traced with your finger to the proper locations and wire tied. Components subjected to high heat should be wrapped, tied safely back, or moved to safer locations. Fuel and alky pressure rise can be checked with power on and applied regulated air pressure. So on, so on, and so on!
And once this is all done.....your still not finished! DO IT AGAIN!!!!!!! Now you should sit around for another week and run through all the other shit you certainly missed in your head.
And this definitely means making sure every sensor and computer controlled device should be in place and set as close to perfect as it can be before flipping the key.
I can't even believe how many retards have caused costly time consuming frustrating errors because they just "wanted to get it running". I mean, for Christ's sake! Do you need to get it running because your going to be late for work tomorrow? Do you have to rush someone to the hospital? Even so, let them die!
There will still be somethings that can't be done until the car is running. I understand this more than most. But.....bla bla bla.
I'm done, my rant is over. I'm happy again.
