hey have you seen my last post on my idle problem also when you turn the key on is the check engine light suppost to flash once every time also can you tell me were to set the two timing knobs on the trans +
Can you list out all the values on the scantool when idling?
Also get the exact part# off the injectors to make sure the chip is matched to the injector. The part# is on the side of the injector. You may need a flashlight to find it.
Well, all the numbers look good there. Do you know if your park/neutral switch is working?
What exactly is the car doing?
Those injectors are the 009's, so we're good there.
yhea im pretty sure that the N/P switch is working, and the car just runs ruff at first till i hit op temp and then is fine also ill get a buck or two out of it
