Boost231, this is what i have so far -
84 T - under construction - Motor rebuilt by Precision Engine Machine, TA forged pistons w/ ceramic coating, rebuilt stock heads with ceramic coated combustion chamber and exhaust port, TA V264 Cam 231H.464"-208'/.464"-208',112', TA 4340 Forged Steel Rods, Total Seal Rings, new HD rocker arms and springs, Hot Wired Aeromotive fuel pump, Bosch adj regulator, rebuilt stock turbo with upgraded inlet bell, SS upgraded headers, 48# Accel injectors, 87 ECU and ignition w/TurboTweak chip, EGR block off, electric fan, Big Mouth cold air intake w/ K&N, 160 thermostat, adj bleed valve/boost controller, 2 1/2" dual exhaust w/o CAT.
Everything else, trans, converter, rear, are still factory. In addition to the engine I did box my rear arms, and replaced bushings with urethane, added a Kirban's snubber, and put in rear seat brace (homemade).
I am replacing my down pipe too, with something similar to stock, just bigger. I am having it built to bolt up to the stock housing.
thanks,
Mike
