Paul Bellisario
- Feb 25, 2013
so with all the mods you see I have i need to decide on what turbo size to go i know i defiantly want a precision. i want something that will be good for my set up now and when i decide to do more mods and get a bigger stall also. I was thinking 5858, 6262, or 6266 what do you guys think? 11s would be nice now and it would also be nice when i upgrade more not having to buy a new turbo again...
(TTA)
60# injecters tubro tweak chip, alky kit,160 thermostat, power logger, 3inch u pipe ,rjc power plate plenum
100# valve springs, walbro pump hot wire kit regulator, rjc boost controller, fresh trans, fresh head gaskets/stock heads, dual fan bypass, drag radials, 3inch dp ,dutt neck ic
valve cover breather
3in maf kn pipe
torqe brace
aem sideband and boost gauge
62mm ported tb
(TTA)
3in maf kn pipe
torqe brace
62mm ported tb
