I'm Stumped!..
No Blown fuses whatsoever. Half of the Fuse Box is getting power.
Fuse box isnt getting any power for : Radio, CIG/CLK, Ins/LPS,Gauges,Tail LPS neither are the battery slots for constant 12v?
Tail Lamps dont work however when you hit brake they light up.....
The Horn works the car runs and drives scanmaster works AC works Boost / rpm lights up but nothing else?I checked all fuses none are blown!!
Checked Fusible links they look good.. None look burned?
Any ideas? Thinking possible Dimmer switch?
