Just an update got the new timing chain installed, new cam button,oil pump thrust plate,and gears,cam sensor set with the kirbin tool,new timing cover,new high flow water pump and 160 thermostat,new oil pan gasket,and cleaned the pick up screen which was just about covered in crud (glad i did it).Also found some bad vac hoses on the turbo and actuator, replaced those,and now the car runs like a champ. All because I had a leaky crank seal! still waiting on my new wire set and intercooler hoses from kirbin. Once again thanks for the help to all!
