Ok 1st JASTRCKL - The car gave the code (i believe code 42) but now that code is not up so I don't believe it is a factor.
I will check for vacuum leaks and replace ALL vaccum lines and check charcoal canister as well as order a billet vac block like CHUCK suggested.
Ormand - I will also blow out the lines from tank pressure and return to check for blockage.
Thanks, anyone else have any other thoughts?
