still trying to trouble shoot my charging woes. i don't have access to a stock charging system to look at and i am not 100% sure what wires go where stock. i have a quad air booster on car installed by previous owner.
anyway my questions. there are 4 letters on the plug for the alternator. i can't recall the order but the are S, F, L and P
P: does not even have a connection so i am not concerned with that one.
L: i understand is lamp, if grounded by the regulator it turns on the dummy light in dash???
F: field. is this the wire that should have power from ignition switch?
S: sensory??? what does this do?
how many wires should the oe setup alternator have coming from the plug? what are the colors? which color refers to L and F if it it a 2 wire setup??? all i seem to have is a brown wire.
thanks. google is not my friend today. i've been trying to figure this out myself with zero luck...
