BRF case was busted had a universal case done it has never worked correctly (altho it is a nice trans) well built! i decided to fix this one who should the trans go to?? should i take the car or just the trans? don't want to spend cubic dollars but want it right at the same time... trans has less then 3k miles shifts hard when it shifts ..leaks out of the front pump doesn't shift into OD until better the 60mph.... think its got the wrong Valve body and gov .....
anyway i'm in so cal who in the area should i go to thanks
