slimtastic
yea dude...I rock
- Aug 9, 2002
ive got a engine combination coming together and everything is planned out basicly but before the few last details are set in stone i wanna run this combo by you fellas to see if this collection of parts will land me into the tens and all the while looking almost stock,minus a front mount, dp and a tb
as follows
basic 109 block .030 over trw's w/ ceramic top and antifriction
stock rods and crank/machined, all billet steel mains, studs
billet roller cam setup from SE Turbo.
ported iron heads w/ferrea valves, roller cam springs,1.65 T/D rockers, ceramic combustion chambers and exhaust ports, studs as well
matching intake(modified stocker kicked out to match felpro1200's)
70mm tb and precision plenum w/ powerplate
stock pass side header and aftermarket crossover and dr side... i cant remember the name.
ls1 maf and translator plus
front mounted intercooler bar and plate style core 12x24x4"
3600 stall w/ lockup
pts extreme transmission
3.5" thdp, not bought yet, too big? too small???
alky kit not bought yet....suggestions???
injector size....i wanna guess 72's???
ive not bought a turbo yet and wanted to go big and stock appearing... which is why i think precision the TA64 would go nicly with this combo. is this turbo gonna cut it?
any other suggestions in general on my emgine would be helpful
as follows
