randy winn
randy29
- Apr 14, 2012
I have te44 turbo with rjc controller can't get but 21# of boost no exhaust leaks no vaccume leaks any suggestions would be appreciated
SignUp Now!Yes and I checked the puck tohd wastegate
Wire the wastegate shut. This will tell you if you need more force to keep the wategate closed or if you have another problem. You could first remove the boost signal from the actuator.Tightening the actuator rod has no effect?
Yes and anticipate skyrocketing boost. Watch your boost gauge and roll into the throttle in third gear.Do you mean remove hose from actuator and plug hose
Alot more than 21. 30 psi easily.no I have not enlarged the hole. Going to try unhooking wastegate hose tomorrow. how much boost should this turbo make.
Im at 27-29 with everything mentioned in this threadno I have not enlarged the hole. Going to try unhooking wastegate hose tomorrow. how much boost should this turbo make.
although im a real fan of thisWire the wastegate shut.
have a fast foot 30 psi comes up quick on a 44no I have not enlarged the hole. Going to try unhooking wastegate hose tomorrow. how much boost should this turbo make.
you could take the controller off and try going right off the rod.could be a puck issueno I have not enlarged the hole. Going to try unhooking wastegate hose tomorrow. how much boost should this turbo make.
What are you using to control boost?Ok guys finally got to work on car today. I un hooked hose to actuator and tried it. In third gear it went to 25# quick so I guess my controller is bad right?
