I am getting ready to redo my 9’x12’ kitchen floor and I am going to put down 12"x12" ceramic or porcelain tiles.
I will be putting 1/4" cement backer board over the existing plywood (I think it is 5/8 thick but not sure).
Here are my questions if anyone has ever done this before or is in the construction biz:
1) The instructions say to use mortar between the cement board and the plywood...and to screw it down with a LOT of screws. Do I have to “glue” the cement board down or will the screws do the job? If I glue it down do I need to use screws too? A Lot of screws?
2) says to stagger the seams – cut the cement board into a lot of pieces so they do not all have the same seam line. Keep the seams of the cement board away from the seams of the plywood. I agree with keeping the cement board from mirroring the seams of the plywood but do I need to stagger the seams of the cement board?
3) Does cement board need to be predrilled for the screws or can I just go through it? It looks like it might crack but I have no experience.
4) Says to make sure the plywood floor is at LEAST 5/8” thick. Mine is at most 5/8” thick as far as I can tell but doubt it is much more. House was built in 77 but I have no idea how thick it really is. Does it matter that much? I don’t want to end up in the basement ;-)
5) pre-mixed mortar or mix it myself?
Thanks for any suggestions, comments, experiences…etc…that you can offer.
