SignUp Now!He's sorta right.
whats happening (in my opinion) with this part throttle surge is: High pressure and low flow.
The wastegate is set for ~ 20+ psi, and the turbo is creating 20 psi in the intercooler, but the driver has backed out of the throttle to limit manifold pressure.
So the turbo is running full boost but the flow is being restricted. This puts the turbo in the surge region of the compressor map.
2 solutions: dampen the surging (his resonator, a tornado, stock MAF, stock intercooler, whatever), or reduce the wastegate setting at less than WOT (there are a couple ways to do this).
__discuss__ ....
Bob
A solenoid style closed loop boost control that w
Thoughts?
Rick
ISAC can do this.
SD2 can do it also.
the wastegate programming in the chips can be set up to do it also.
the aftermarket ECU's can be set up (most of them) for this.
very few aftermarket boost controllers have a TPS input for stuff like this.
Bob
pretty much all chips. the stock software has a wastegate vs tps table, but nobody really uses it.
actually I think I removed it from most of my recent chips to save space, I would need to look.
as far as TT, you would need to ask Eric.
Bob
What a shame, there does not seem to be a clear cut answer to this problem. Lots of posts, do this do that, go broke doing all of this. Use the Tpro and get a smiley face from Bob, whatever that means. Use a BOV, ok what's that going to do if your not using SD2. Go with the ISCA, ok every member thinks the rest of us fell out of the womb knowing what that means. There have been lots of posts about this issue, however there does not seem to be a overall fix. Ever the big dogs on this site don't have a good answer.
Ok, that's cool. Just want one cat skinning, which is ???More than one way to skin a cat: bottom line, either the engine needs to eat more or the turbo needs to slow down during the times that surge is experienced. How you do that is what we are discussing and I refer back to the cat thing.
