- Nov 4, 2005
im going to do some track testing w/data logging and need some info;
right now after new parts(dp,ic,tc,both fp's) installed,my starting point is 10.0 (maxed out on wb gage),15psi boost,and havent adjusted the TT chip any....
1)what a/f ratio with e85?
2)timing to shoot for?
3)hoping for 22 psi (more?)w/o knock.
4)inj pw max safe? with this boost level/60's
my mods are; (otherwise car is 60k mile stock)....
ta49 (22-25 psi) havent tunned yet...waiting on powerlogger
twin red armstrong xp pumps ( car has big fuel lines)
slic...looks like a bg unit
3.5" dp th style
60's w/tt e85 chip
10" ptc 2700 stall l/u tc
mt dr
208/208 cam...new springs,timing chain,lifters
power plate
torque strap
ungo wideband
pinion snubber, drive shaft safty loop
spring cleaning done
open dump.....if nothing else, it sure sounds good....
thanks for the help.......
3.5" dp th style
60's w/tt e85 chip
mt dr
power plate
torque strap
ungo wideband
