Help with Waste Gate
erfig
Im finally putting my GN back together... Trying to figure out witch waste gate to get... The motor is a stock block worked steel head, using a P trim 70 turbo with 80lb injectors... Hope to install a classic fast system... I both internal and external waste gate down pipes and plan on installing a electric boost control with two stages... i have a internal Turbonetics Dual Port Wastegate Actuators and the external external is a ..HKS GT Wastegate - 0.9- 1.3 kg/cm2 Im looking for a street car that could be able to dip down to low 10 sec... would one of these work with my setup or is there something better suited.
thanks
eric
Witch one would be the most reliable and easier to work with... also how would i set up the one with the Turbonetics dual ports...
thanks for the reply
eric
Imo
Internal gate pipe will give less head ache.
External gate pipes can be harder to get the boost down. Extensive port work to the turbo housing is usually required.
RL
Is the dual port the way to go with internal or is there a better option
RL
i disagree with the external gate comment. if its built into the pass side manifold just before the turbo then boost control is very stable...on my current setup an external is stable down to about 3 psi
an internal gate will be alot easier to setup (cause its already there) but boost control at lower psi like 17 and under with a efficient turbo will be very difficult
Am internal gate with a heavy spring is plenty for this application
The dual port is a neat thing when used with a boost control but would prolly be better off with single port. Less confusion. Keep it simple if you are just starting out. All that fancy stuff will just have you scratching your head. Like Bison says, a tight spring single port actuator and your good to go. :cool:
HTH
RL
i disagree with the external gate comment. if its built into the pass side manifold just before the turbo then boost control is very stable...on my current setup an external is stable down to about 3 psi an internal gate will be alot easier to setup (cause its already there) but boost control at lower psi like 17 and under with a efficient turbo will be very difficult
It's all about spring pressure and waste gate port efficiency. That being said, yes a external gate will control boost better off the header but the op was asking about a external gate pipe. 2 totally different set ups. The boost does not have to squeeze through a little hole in the exhaust housing and make a couple drastic turns to escape.
RL
How would i hook up the dual port gate... i have a elec boost control... i had a gn back in the 90's was pretty handy with it.... alots changed in 10 years....
