Help with Z06 card style maf and gen 2 setup
Dunebilly
Hi I have the gen 2 translator hooked up and running with a 3"lt1 maf my question is I have a 4"maf sensor/maf pipe all in one that I want to use but when I tried configuring it it would not start .I tried maf input 4" mega maf and output gm stock (I think this is correct )the sensor is a card style Delphi that plugs directly to my gen 2 harness with the 5 pins I just don't know where to go next ...any input would be a blessing thanks
my chip is a tt 5.7 chip and I have sm and pl 3.0
I would make sure the wires from your stock plug to the new plug/sensor are correct.... Start with the simple trouble shooting first.. Do any MAL codes show up?
can you take a photo of the wiring from the stock harness until the MAF card
ok I've reset the gen 2 and tried again the settings for the 4 inch ma .... my gen 2 says its a 1.35 version my question is do I need to use a different version or is 1.35 up to date because the car will not start.. I have a tt chip in it for now and I chose gn stock maf out ...any help would be awesome
What did the wiring to the adapter harness look likeo_O i never saw the pics
aaron
1.35 is a current version number.
the 4" megamaf is what you want to choose for MAF In
what are you seeing on Freq in and Freq out?
Bob
