Hey Guys,
Here is my 2 cents.. for what it is worth
99% of the drilled rotors (or any surface modifications, slots, dimples etc) are purchased due to cosmetics. They were originally designed for outgassing of brake pads. Pad technology has gotten MUCH better, and this isnt so much of an issue nowadays with better quality pads.
For street use it is not an issue (usually) since in most cases these cars will never see the abuse a track car will see. For track cars we do not recommend drilled rotors. The thing is with track cars in most cases rotors will fail due to cracking (even when plain). All rotors are basically grey cast iron and they can take only so much abuse/heat cycles before they fail.
The biggest issue with the factory brake system is the rotor is small, straight vaned (left and right are the same), and the caliper is cast iron so it has poor heat dissipation, and real poor recovery when it gets heat soaked.
So basically they are cool looking, ok for most on the street... and not recommended for track.
