snatchSS454
- Jan 29, 2004
Hey all,
This is my first post but I've been lerking for a while. I own a 2000 camaro 3.8. I am in the process of building an engine(l67) for boost. It will be a 75% street 25% strip car. My current plans are:
L67 block
8.5:1cr forged diamond pistons
GTP series III rods
clevite 77 bearings(all)
arp engine fasteners/head bolts/connecting rod bolts
MLS head gaskets
p/p stock heads w/ 3 angle valve job and comp cams 105lb springs
60-1 TO4E T3/T4 hybrid turbocharger-0.6 A/R compressor and 0.8 A/R Turbine
I need bigger injectors and a cam which are the areas that I have no idea about. I would like to run 12-15psi continuously and 20 from time to time.
I have read alot on here about the 204/214 cam being a nice camshaft and was wondering if it could be used in my application(a custom comp grind with the same specs of course). People at camarov6.com seem to think a cam with more intake and less exhaust would be better, such as 114.5lsa,214 intake dur,208 exhaust dur,.510 intake lift,.496 exhaust lift. I would like to get your opinions on this! Also what lb/hr injectors would you recommend. Im shooting for 4-450rwhp. I also have a stage II transmission with an Edge 3000 stall converter and 3.42 posi rearend. Any advice you could lend would be great!
Thanks in advance,
Shane
L67 block
GTP series III rods
MLS head gaskets
Thanks in advance,
Shane
