Pittsburghkid
Displacement Replacement.
- Mar 22, 2009
Post where you're located. There may be someone nearby who can help you.
SignUp Now!im in long island nyPost where you're located. There may be someone nearby who can help you.
You don't even know yet whether the head bolt threads were even sealed properly. You need to know that before a re torque.
That's one nasty looking WRONG alternator!!!.
To add to above. I used brake cleaner to clean the surfaces. I kept a rag over the valley and have head of others that squirt some foamy shaving cream in the cooling ports to keep debris out.
I bought a top end kit from full throttle. It was around $90. Victor Reinz. I figured it would have all the gaskets and an extra set for the next time. I also went with studs but since only one side was blown only one side of my engine has the studs. If it ain't broke don't fix it is what my grandfather used to tell me.
I used Indian head shellac stuff on the studs that go into the block. I've heard the loctite 567 is good too but I've not used it . I have used the Indian head stuff successfully countless times on many different engines. Also good for front cover bolts that go into the water jacket.
Post up with any more questions.
Not hard. Take pix. Put it back the way you took it apart. Don't over think it.
Rich
thanks.
so far I bought the head gaskets
bought a full spring cleaning kit that I pieced together
ordered the studs
bought the vacuum tubing.
is there anything else I need to buy beside some thread sealer?
what are sealing tabs? I have never heard of them.
is this the correct intake manifold gasket? http://www.pepboys.com/product/deta...ntake_manifold_gaskets_components/?quantity=1
thanks for the supportIm in Connecticut. Dont let it freak you out. We are here to help. Post pics when you get stuck. We will get you thru it. Then you will have to upgrade to the coveted gold membership.
Sent from my SPH-L720 using Tapatalk 4
