87 national
- Mar 31, 2010
should i order a high volume or just stick with the stock my motor does have some mod like 66 turbo and some one has been in the motor with upgrades. what do you suggest? thanks
SignUp Now!I would NOT suggest using a hi-volume pump on just about any engine. If you control the oil leaks during engine assembly, there is no need for one. The stock pump, albeit very primative, works great. I keep the pump cover to gear face clearance as close to .0005-.0015 as I can. (half a thou. to one and a half thou.) I radius all the passages in the cover AND block, keep bearing clearances to .0017"-.0019", rotate cam bearing oil feed holes so they are partially blocked (you can drill new .050-.098" holes if you like, and rotate the original feed hole away from the passage) and you can even reduce the pushrod feed holes if you run roller rockers. (though probably not worth the effort) Good remote oil filtration system will help, too. But,......a completely stock oiling system is adaquate for more than 500hp. So, unless you are a extremely technical guy like me, leave it stock, and keep the bearing clearances tight. Oh, ya, leave the oil pressure gauge in the garage, too. That way when the pressure drops to >15psi at hot idle, you won't freak-out.Nothing wrong with only 10 psi of hot idle oil pressure. As long as it jumps to 40+ psi at throttle tip-in.
I have the hi-vol cover and pump on my engine.
It has 10-15 hot idle and 40-50 at highway speeds.
Should I replace the front cover/pump with a stock one?
Just to throw out a little fun math for you....
It's pretty common knowledge not to drill out aftermarket covers to 1/2". From what I've gathered I understand they like to either blow out the side or vent to the adjacent bolt hole. (I can't say first hand as I'd never consider putting one on my personal car).
The area of a 1/2" hole is .196 square inches. The area of a 7/16" hole (which I think aftermarkets and stock untouched covers are) is .150 square inches.
