Do you need a wiring harness with this hid kit?
Ha ha, I thought I was the only one.![]()
In my post with the pics of the hids, that is what you need and get. Comes with everything you need from ALRADCO.
I think if I went this route with the hid installation kit, I would use a hid wire harness just for safety. The hid's draw alot of amps to fire them up from the start then taper down on the amp draw. I don't know if the factory wiring can handle this amp draw on start up of the hid's. Just my opinion, thinking safety I guess.
Had a couple PM's with questions but while I was at work, Peter answered most of them. (Peter, get back to your vacation! :biggrin: )
Here is a pic as requested of the HID vs original. If looking directly from the front, you can slightly see the darker center area which is the bulb. From any other angle they look like a normal light. Hope this helps!
James
C5,are these units plug n play?? thanks
Ron
Installed the HID low-beams from Alradco over the holidays and man-o-man these things are great! Nice and bright and the install went very well, nice kit, good company to deal with, thank you Peter.
Mike
Hey Peter, do you have a HID kit for a 95 Trans Am with the single big square headlight?
