SignUp Now!^^^ I'd listen to what is said here. Yes, Ronnie's my friend but he won't BS you about what does or doesn't work. He does it for a living so he probibly knows what will work best. Al (aminga) also has a point and is learning how to do his own powder coating with Ronnie helping with info. Powder it and don't look back. Is it expensive? Yes! but it will hold up the best after all.
I used this on my 64 Lincoln's manifolds. As far as I am concerned, everything besides this and ceramic coating is temporary. At $20, one container will do at least a dozed V8 headers.
Calyx Manifold Dressing
It seems like its just graphite mixed with toothpaste for a carrier. The carrier just burns off and leaves the graphite shell.
Look into Techline Coatings.
Do you know if there is a temperature when using this? The EGT temps for the turbo buicks manifold's can run above 1600F.
Because of their awkward flow/poor design, my Lincoln headers get to be 'nuclear reactor hot' I forget the actual temps that have been measured. I have had no problem. I believe since it is basically graphite, there is no max temp. Maybe if they get hot enough it will crystallize into diamond?:biggrin:
FWIW, As soon as I get my GN's engine back together, I plan on using the Calyx on my headers, crosspipe, and turbine housing. It definitely is easy to coat, since you just dip in a toothbrush and scrub it on. Smells minty too.
Thanks.
