AutoMeter Hood Mounted Fuel Pressure Gauge
I installed a hood mounted fuel pressure gauge on my GN 2 weeks ago
I ordered the Fuel Pressure Gauge & Hood Mounted Cup / Bracket from the same source (www.egauges.com)
I chose the AutoMeter Mechanical Fuel Pressure Gauge - 2 1/16 Dia / 100 psi / PN # ATM-3312 = $40.00
They also offer numerous universal mounts ( i.e. #240-016) for the hood that range around $20.00
I then bought the double fuel rail fitting from Caspers (I run a fuel rail, fuel gauge as well) around $20.00
And to finish it off i went to the local steel braided hose company (TMR) and had them make me a 42 inch piece of tubing with the proper connections for the gauge and the fuel rail adapter = $24.00
I positioned the gauge mount bracket on the hood in the proper position / angle and secured it to the hood by double sided tape. I drilled a 1/2 " hole in the hood to run the steel braided line / power wire, installed rubber grommets to protect the steel braided line from chaffing, and mounted the hose securely to the fuel rail
I back light powered the gauge by tapping into the orange wire behind the headlight dash switch and by grounding a point in the engine bay. Now the gauge is illuminated with the headlights and dimmed with the dimmer.
Total cost approximatly $100 dollars and about an hours time to install
The look is great, and it does get alot of comments
Good luck
Ray
Good luck
Ray
