Mar 26, 2011 #1 R rorock23 New Member Joined May 1, 2009 Messages 7 I need someone in Indianpolis,IN area who work on these cars!!!
Mar 26, 2011 #2 phvrod FAST WITH CLASS Joined May 19, 2008 Messages 144 phvrod Im in Plainfield..10 minutes away...What do You need?
Mar 27, 2011 #3 R rorock23 New Member Joined May 1, 2009 Messages 7 phvrod said: Im in Plainfield..10 minutes away...What do You need? Click to expand... need to get this thing running..
Mar 27, 2011 #5 R rorock23 New Member Joined May 1, 2009 Messages 7 no fire it cranks but no fire ...I will be working on the fuel system tomorrow..
Mar 28, 2011 #6 Anarchy One fast Hot Air Joined Sep 9, 2010 Messages 713 you should check the ignition mod. or the coil pack. that is whats wrong with mine. but im having trouble locating the ignition module on my car. i can see the coil pack right in front of me but i have no clue where the ignition module is located.
Mar 28, 2011 #7 B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Messages 3,588 The ignition module AKA coil module is attached to the bottom of the coil pak. It has the wiring harness plugged into it. Brad
Mar 28, 2011 #8 Anarchy One fast Hot Air Joined Sep 9, 2010 Messages 713 thanks man. now i feel like a a$$..lol. its right there in my face the whole time..lmao... wow daaaaaaaaaaaaaaaaaa!!!!!
Mar 28, 2011 #9 Anarchy One fast Hot Air Joined Sep 9, 2010 Messages 713 i have a 86/87 ecu. does that matter what ignition module i get. or can any just due fine. or does it have to be a 86/87 module.
Mar 28, 2011 #10 B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Messages 3,588 You need an 86/87 module. I have a good after marker used one which means it will not run an after marker tach. Let me know, Thanks-Brad
Mar 28, 2011 #11 Anarchy One fast Hot Air Joined Sep 9, 2010 Messages 713 and i would need a 86/87 coil pack as well. cuz im planing to swap both at the same time.
Mar 28, 2011 #12 W WFO Habitual Line-Stepper Joined May 24, 2001 Messages 1,844 Do a search for type II coils. Cheaper,way easier to find in junkyards. I've been running them for years. Type II Ignition Swap
