Jul 3, 2007 #1 R ronbuick Active Member Joined Jun 12, 2001 Messages 1,587 What are all you folks using for head gaskets for the hot air motor, and what choices do we have. thanks Ron
Jul 3, 2007 #2 B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Messages 16,741 stock is what im using. there getting hard to find.
Jul 3, 2007 #3 R ronbuick Active Member Joined Jun 12, 2001 Messages 1,587 I have been told by a couple of parts houses that the N/A and the turbo motor take the same head gasket, is this true?? Ron
Jul 3, 2007 #4 8 84HAGN New Member Joined Jul 6, 2005 Messages 188 no No they are different i think they have different compressed thickness and different compositions I use the felpro 1000 and have had good luck but others will chime in
Jul 3, 2007 #5 conn84gn Well-Known Member Joined Jul 13, 2005 Messages 1,372 84 block 87 setup ++++ Felpro 1000 20lb boost ++++ Long as you have enough fuel they will do fine
Jul 3, 2007 #6 B BRAD_PADGETT Well-Known Member Joined Jan 22, 2004 Messages 3,588 I use Feldpro 1000. I am a happy camper. My 2 cents. Good luck- Brad
Jul 3, 2007 #7 G garrett Member Joined Oct 28, 2006 Messages 530 headgaskets 84 block/87 set up RJC headgaskets-20lbs of boost with alcohol ARP studs
Jul 4, 2007 #8 B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Messages 16,741 84 block stock heads and gaskets ran 25+
