how do you take off the windsheild washer arm
Which arm?
If you look closely there is a little 'Shim'/'Lever' that you have to slide over before you pull the arm off. It sticks out a tiny bit at the base. After you slide it over just wiggle it back and forth and it should come right off!
If you look at the bottom of the arm at the pivot, on the top side there is a little lever, pull up on the spring loaded part of the arm and pull the lever out with a screwdriver and when you let go the arm will lock itself and you can just wiggle the arm off the pivot.
Eric Fisher
