I have a GN 8.5 rear for my Malibu and am in the process of building a stroker LT1 with a Tremec TKO 5 speed with nitrous. This would be more than enough power to put the car into the 10's.
What is the limit of the GN 8.5 rear when used with a good 30 spline after market axle and a 800 pound preload after market Eaton?
I spoke with a gentleman that runs A&D auto in New Jersey and he explained that even after I add those items and a girdle that the weak point becomes the axle tubes since they are only 2 3/4". He said the amount of flex a high horse power engine puts on the rear can still break an axle because of this flex.
He recommended that I go with a 12 bolt since it has 3" tubes that are actually have a thicker wall thickness than the 8.5.
He also recommended against using 33 spline axles at all since the inner diameter of the carrier where the axle goes in, makes the carrier bearing register paper thin thus creating a weak spot.
Lets hear what some of the mid 10 second and faster guys have to say.
2 things I have going against me are the stick and the nitrous, both of which hit the rear way harder.
