i've always hated that vac block and how the solid lines snake and wrap around the engine.
While I had my 4.1 out and apart to install my forged pistons I did a vac brake swap (see my how-to a few posts down), steel braided lines, and new rotors and bearings (how-to coming soon).
While my intake was sitting on the coffee table I thought it would be fun to bust out the drill motor and make some shavings....
After a few minutes, i settled on this...
The large elbow on the left with the check valve is for my vacuum brake booster. Now that the engine is installed I'm going to swap it out for a standard straight barbed fitting. The hose will route nicer that way.
The one in the middle is for the small vac line that used to run the EGR and still runs the vac ball, charcoal can, basically the stuff on the drivers side engine compartment. The right one is for the MAP sensor and boost gauge. It will probably get swapped for a straight barb too.
Next I chose this spot for the fuel pressure regulator. This one was a little tricky because I needed to make sure the nipple (giggity) and the line would play nice with the trottle/cruise/TV cables.
Also, i think my throttle body is now officially out of the leak business. It seems like the factory hose were close enough I didn't even have to drill. All it took was pipe taps and sealing jizz.
I'll probably make a cosmetic plate just to pretty that up a little. That does go against my thing of adding weight with no performance gain though.
Installed and routed.
I ddin't think to weigh everything up and see if I actually lost any weight. Since I added a vacuum brake circuit it would most likely be an apples to giraffes comparison.
I do enjoy not rubbing by discontinued hood liner anymore. So that's something
