SignUp Now!Hello!!
Just took my newest one out last night.
I need to do some tuning tweaks and port the wastegate hole on the GT67.
I have a flat tappet cam,non BB turbo,3400 stall.
Boost is instant,like yesterday instant.
Gave it a little over 1/2 throttle and the boost hit 20#!
The boost setting in the chip is supposed to be 16# but the wastegate hole is most likely the culprit.Hit 25# instantly when I took it to WOT at 40mph and roasted the tires until I let out. I have 93 in the tank and luckily it didn't huirt anything.
The motor has hyper pistons, 214/224 cam,champion irons,Gbody slic,60#ers,and the stall converter,with a gen 2 translator and 4" maf pipe.
I need to figure out the tuning on the gen 2 as it is stalling on me at stops,cruising and WOT are fine.
That's cool to hear......Sounds just like the same build I'm currently working on minus the Gen 2.
Don't mean to Hi-Jack
But what has to be done to the 4.1L to handle boost. Could I put 86/87 parts on and go or does it really need to be built to handle the boost.![]()
I just had a 4.1 thrown together a few weeks ago, cool 84- I finally used those new pistons i purchased from you many many years ago![]()
This will be my second 4.1, and i agree with the off idle torque and boost coming up quick!
I will be using the same combo as the last one, larger 66mm turbo, ported heads and a 218 camshaft. Nothing wrong with mid 11s on low boost, just enough power to start breaking parts :biggrin:
BW
low compression pistons which are the only ones available.Thats it and bolt up all the 3.8 stuff add about 10% fuel across the board to your 3.8 tune.
Now thats riding!!! I hope mine gets close to that. The block checked out, so now i got to get 30over pistons, but i cant seem to pull them up on summits web site.10.23 at 132 mph, with stock heads at 25psi
My last one had a 218/218 cam and te63 with a front mount and 3200 stall,Old T+ and extender chip.
Could run low 11's all day on 93 and 16#.Drove it an hour both ways to one of the local 1/8 mile tracks and ran 7.17 and hot lapped it and ran 7.18 @ 98mph without letting any air out of the tires (had 30# in them). Took the car down the track just like I drove it in the gate.No ALKY either.
i seem to remember you hot-lapping it into the 6's one night against a corvette![]()
