SignUp Now!With a 212-212 flat tappet and mildly ported stock heads, I've accidentally bumped the limiter at 6,200rpm a few times and it was still pulling hard. I think it's safe to say that with mildly worked stock heads and intake, you can run more rpms than the stock bottom will take. I've thought about going to a bigger 218-218 cam with my 4.1 but I don't see the point if it pulls hard to the limiter already.
At how many miles should the springs be replaced?
And with which ones?
Someone who has bothered to monitor their spring pressures on a mild build would have to answer that for us.
The spring to use as a replacement should be what the cam maker recommends.
With my setup, I check the valve adjustments (mechanical rollers) and springs every 3rd outing. I should do it more often, but the adjustments have stabilized pretty well. I look for broken springs, abnormal wear and check the seat pressures (incar) with a special tool. It's been recommended to me that if I see a drop in seat pressure of more than 10 psi, it's time to change the springs. The springs drop pressure pretty quick and I've let it go longer than I should. I'm waiting for my new set of springs to come in, as a matter of fact.
I have a friend with a Reher Morrison engine, and he's been instructed to change his valve springs every twenty something runs. Egads!![]()
